need 4x4 help
Old Jan 10, 2008 | 09:06 PM
black95blazer's Avatar
black95blazer is an unknown quantity at this point
Default need 4x4 help
ok i have a 1995 s10 blazer.. i have the elec dash push buttion witch i thik sucks. some times my switch wont even light up but some titmes it does. then when i press the four high button the light will light up and the drive shaft will lock for the four wheel drive but the fron axles wont lock in. it does the same thing in 4lo so if some one could help my why my switch wont lgiht up and why my front axle wont lock in.. thanks/
Old Jan 10, 2008 | 09:08 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
Default RE: need 4x4 help
faulty switch
Old Jan 10, 2008 | 09:10 PM
The switch not lighting up is mostlikely either a loose electrical connection at the switch or an intermittent connection in the switch itself.
With the front axle actuator, it is likely a problem with either the vacuum supply to the front axle engagement actuator or the actuator itself.
Old Jan 10, 2008 | 09:23 PM
thanks will let u know what goes on when i replace the switch
evlblkwpnz
Dec 18, 2009 08:26 AM
sdm1234
Feb 7, 2008 06:16 AM
black95blazer
Dec 11, 2007 05:45 PM
blazinloud
26
Mar 4, 2007 03:25 PM
