NOISE!! haha
Old Aug 7, 2009 | 04:38 PM
19jimmy99's Avatar
19jimmy99 is on a distinguished road
Default NOISE!! haha
i have a prob i had my 99 jimmy in to the garage today to get a noise checked out and the fella said my front end is all good and he cant find out what the noise is he can here it when he takes it for adrive but dosnet know what it is....it happens when iam driveing down the road and it sounds like my front right wheelis goin to ratttle off any body shed some light on the situation
Old Aug 7, 2009 | 08:33 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Jack the front up and spin the wheel it's possible you have a bad wheel bearing or hub
Old Aug 7, 2009 | 09:05 PM
19jimmy99's Avatar
it only happens wheni hit bumps which is near all the t ime hear but you still think the same thing???
Old Aug 7, 2009 | 09:13 PM
reelbroke2's Avatar
when its jacked up put a bar under the tire and pull up(move the tire in and out) ,see if there is movement in the ball joints as well
Old Aug 10, 2009 | 10:12 AM
hotrod413's Avatar
hotrod413 is on a distinguished road
happend to my 2WD. The caliper pins broke, and would wriggle their way to the rim when I hit a bump. Made a terrible scraping sound. It almost made a rattle like the bumper bolts were loose. It would only do it after I hit a bump though. Check it out. Its only a 5 dollar 2 minute fix
flame suit ON for posting autozone link
http://www.autozone.com/autozone/cat...Name=Brakeware
Old Aug 12, 2009 | 05:27 PM
Radar Locust's Avatar
Radar Locust is on a distinguished road
Is there a vibration associated with it, or is it just a noise?
Check all your bushings (Including the engine mounts).
Also, unfortunate experience has taught me that although you think the noise is coming from the front right it could be coming from somewhere else like the drive shaft or torsion bars.
Old Aug 13, 2009 | 03:22 AM
foxxie's Avatar
Had a knock in the front of another car I had once every time I went over a bump, finally tracked it down to worn D bushes holding stabiliser bar to chassis.
Old Aug 13, 2009 | 05:04 AM
kiwiblazer's Avatar
I've got a knocking sound in the front of my truck. Sounds like a broken shock or something. Sounds like it is actually in the dash or just behind. Also considered the wiper arm knuckle could be worn. Maybe steering column, who knows! Nobody has been able to identify it. I think foxxie may have the answer - to my problem at least, but these may be areas to consider. Maybe, thinking about it now, each time the wheel bounces on the rough surface it relieves the tension on the front sway bar enough to have it loose & that causes the "knocking" sound. On a smooth surface I don't seem to have the noise.
Make sense, anyone? Or am I talking ..... LOL
Old Aug 14, 2009 | 05:19 AM
foxxie's Avatar
You are right on the money with the problem I had, sounded like a lose shock every time I went over a bump.What was happening when the tension was taken off the stabiliser bar knocked against the chassis, a $10 fix.LOL
Old Aug 14, 2009 | 10:40 PM
19jimmy99's Avatar
hey all what i thouhg would be an expen sive fix ended up being a 7 dollar fix for a new bracket on my hood which had worn out ....thanks for alll the input it took a half dozen guys at the garage to figure out a 7 dollar problem....haha dont always figure the worst like me PEACE i am out
