Over-filled power steering fluid...
Old Dec 1, 2010 | 09:30 PM
JTalley's Avatar
JTalley is on a distinguished road
Default Over-filled power steering fluid...
I was a little low on power steering fluid- just enough so that it squealed a little bit. I had to put more in it, but it was dark by the time I got it, and I can't do it in the morning, so I had to go out and put it in there in the dark. Nobody would help me with anything, so I ended up overflowing the thing. Is this bad? Should I get a turkey baster and suck it out?
Old Dec 1, 2010 | 10:09 PM
rriddle3's Avatar
I would break out the baster (clean, of course).
Old Dec 2, 2010 | 06:15 PM
LowLife's Avatar
LowLife is on a distinguished road
Lightbulb
i have done the same thing before....to much fluid , U can just pull out your air box throw a drain pan under the truck next to the driver front wheel, TAKE A 1/4 SOCKET loosen up the clamp and pull the rubber hose off the power steering pump, and let it drain that way you start with all fresh fluid, your p/ steering capacity is about a pint just hook the hose back up and pour it in you should be right on the mark. hope that helps brother
Old Dec 2, 2010 | 07:04 PM
abig84's Avatar
i dont know if itll actually hurt anything but will probably make a mess. ive known people with leaking pumps that would just fill it all the way to thetop... or maybe thats why it was leaking in the first place
Old Dec 2, 2010 | 07:21 PM
LowLife's Avatar
Thumbs up
yea when i did my overfilled it made my steering feel very tight, like the pump was bad... i also think if its left alone for to long i could see it making to much pressure which could possibly case the seal to blow and then you gottas pull the bracket off change the pump with a pulley puller& installer so much of a pain in the @$$ for such a simple fix, plus the pump are roughly 75 bucks
Old Dec 3, 2010 | 03:07 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
I overfilled mine once that was about 6 years ago I just left it and haven't had a problem with it yet.
Old Dec 3, 2010 | 08:57 AM
JTalley's Avatar
I haven't took anything out yet, but so far, no problem. It's still squealing- barely enough to hear it.
97cherryblazer
Mar 8, 2012 02:27 PM
racsan
Mar 5, 2012 07:52 AM
Raybz
Aug 25, 2011 08:30 AM
kiwiblazer
Oct 12, 2009 10:10 AM
swartlkk
Tires and Wheels
Dec 2, 2005 09:06 PM
