Pitman and Idler arm replacement
I think it was 34mm. I don't know how the pitman arm pullers are but you will probably find it easier to take the lines off and take the steering box right out of the truck. Hit the lines with a little heat if they are frozen just don't go overboard because there is a seal on each of them about an inch down. There is no special method for bleeding the power steering unit either after reassembly you just jack the truck up top it with fluid and spin the steering wheel back and forth.
Well I tried tackling this bull**** for the last 3hours but I could not break the connection on the center link on both the idler and pitman, I have no air tho. They wouldn't budge, 2 big hammers tried the fork I can't believe the y are that tight?
Do you have access to even a small propane torch? If so, try heating them, then quenching them with some penetrating oil. The rapid heating and cooling should help free the tapered shaft from the bore.
dont heat anything up. go buy a tie rod separator .. looks like this .. and an electric impact..
those tools... $80 for both at harbor freight, knuckles that are not bleeding ... priceless
use that and an electric impact wrench and everything pops right off no problem
you can use it on ball joints, tie rods, pitman & idler and it doesnt destroy the boots.
with this tool and the electric impact, i can take my front end down to nothing in less than an hour. I tell you what, i wish i would have had this combo for the last 10 years... UNBELIEVABLE how easy all those parts come off with this combo.
I dont know why the hell they even make pickle forks, or more important, why people say you need one. just silly
