Poping nosie under my blazer PLEASE HELP
Old Feb 25, 2010 | 10:20 PM
kevin turner's Avatar
kevin turner is on a distinguished road
Default Poping nosie under my blazer PLEASE HELP
I have a 98 blazer ls 4x4. their is a loud popping nosie coming form under both floor board. Its not like a axle going out its like it pops everytime the suspension works up and down.Hope you guys can help me again thanks
Old Feb 26, 2010 | 06:10 AM
AJBert's Avatar
Take a look at the bushings for the torsion bar crossmember.
Old Feb 26, 2010 | 11:52 PM
What should i be looking, just somthinh out of place? Im a engine man not suspenson. Should i just replace the bars and bushings and if so how much for parts and speical tools if any. Thanks for the reply.
Old Feb 27, 2010 | 05:13 AM
AJBert's Avatar
The bars should be fine. Follow them back to the torsion keys. The torsion keys are supported inside a crossmember. The crossmember is supported by a bushing on each side to the frame. You should be able to tell what shape the bushings are in by looking at them.
If I'm not mistaken, I believe you can only get replacement bushings made from rubber, as I have not seen them from ES or any other aftermarket manufacturer. If someone else knows where to get poly bushings, please chime in! I believe you can get them from Rock Auto, GM Direct, dealership, etc. No clue on the cost, though. I wouldn't imagine they would run too much.
There is a specialty tool required to relieve the tension on the tbars, though you can fashion one up using a c-clamp. Others have used various other means/tools. Do a search and you should be able to find more on how to remove the keys.
Old Feb 27, 2010 | 08:39 PM
Thanks for the help, its a mess out side atm. I will have to wait till it dries up a little bit. I dont like laying down in a mud hole....lol
Brandon Koharchik
Oct 30, 2013 09:52 AM
HiRidinChevy93
Oct 3, 2011 05:59 PM
showboat
Aug 3, 2010 07:07 PM
Stopphn
Apr 2, 2010 10:31 PM
blazer_in_ky
Nov 6, 2009 04:17 PM
