Power steering delete belt size.
Old Feb 10, 2019 | 08:00 PM
Ctank's Avatar
Ctank is on a distinguished road
Default Power steering delete belt size.
Hey what’s going on guys. I’m in a pinch right now. I got a 2000 blazer with a 4.3 with ac. The shaft in the pump has worn causing the pulley to ride around funny and spit the belt I can legit almost take the pulley off the pump. I want to just throw a shorter belt to bypass the pump so I can charge my battery/not overheat the motor until I can get a used one. Also so I can get back and forth to work. I ran a string and must has made a mistake somewhere down the line with my measurements. I had a 70k6 and with the tensioner all the way back was still at least 3 to 5 inches off. Parts stores are closed now. I know someone has had to do this before any help would be super epic!!! Thanks anyone!!
Old Feb 10, 2019 | 09:02 PM
cleburne red's Avatar
Man, I understand you're in a pinch, but trying to drive a power steering vehicle without power steering is gonna be almost impossible at low speeds.
Good luck on your search
Old Feb 11, 2019 | 04:12 PM
For the cost of the belt, could get a pump ag the scrap yard...
Old Oct 13, 2020 | 09:01 PM
thebeelow's Avatar
thebeelow is on a distinguished road
i ride without power steering all the time it’s not that hard you just have to have a little muscle
Old Oct 13, 2020 | 09:02 PM
thebeelow's Avatar
i ride without power steering all the time i just need a custom belt size to fit the rack without the power steering pulley does anyone know ??
Old Feb 27, 2022 | 04:21 PM
wompshmack's Avatar
wompshmack is on a distinguished road
I just did this. 770K6 worked great for me, and I kept the ac compressor in the loop. I had exactly the same power steering pump problem. Hopefully this helps the next person who’s looking for the size, cause this is the first google result.
Old Nov 23, 2024 | 06:58 PM
Rmitchell0902's Avatar
Rmitchell0902 is on a distinguished road
to anybody wondering it worked. Im assuming this will work on any 4.3 because I have a safari and it worked on mines. @wompshmack your awesome thank you.
1965Chevy
Feb 14, 2015 12:32 PM
gmcjimmy_94
Jan 16, 2012 11:20 PM
iloveblazers
18
Oct 10, 2010 10:06 AM
daveg999
Jul 6, 2010 12:52 PM
blazinloud
May 2, 2009 10:51 AM
