Power steering pump pulley removal
Old Aug 14, 2014 | 02:05 PM
frankma52's Avatar
frankma52 is on a distinguished road
Default Power steering pump pulley removal
1994 Chevy Blazer 4.3 liter V 6 Vortex.
The high pressure hose is shot and I need to pull off the pulley to get at the hose. I have read the post regarding this and is there a bolt on the front of the shaft going though the pulley to the pump. I am confused. The thread says that there is no bolt and the pulley puller will pull off the pulley. I am looking and there is a hex wrench type hole in the front of the shaft, and I tried to remove it, but it won't budge. Can you please confirm that there is no bolt to remove BEFORE adding the pulley removal tool.
Thank you,
Frank
Old Aug 14, 2014 | 10:10 PM
odat's Avatar
most are pressed on - and as you prob know it takes a special puller - a typical gear pulled with the arms won't work
Old Aug 26, 2014 | 10:55 AM
frankma52's Avatar
Default Power Steering Pump Pulley removal
I thought so. I bought the pulley removal / install tool from Harbor Freight for $20 bucks and it worked like a charm, not that removing it wasn't a nightmare. It took me awhile, but I got the pulley off. Once I had the pulley off, I removed the the bolts holding the pump and was able to remove it and take off the old high pressure hose for the pump. I installed the new hose and re-installed the pump back in, then I used the tool to install the pulley, making sure it was flush to the power steering pump shaft. I put everything back together and installed a new belt.
low1
Jun 23, 2012 12:22 AM
afojc
14
May 23, 2010 01:25 PM
ant2297
Dec 27, 2008 04:25 PM
matclark
May 27, 2008 10:32 PM
irata
Jul 7, 2007 03:36 PM
