Questions on Solid Axle Swap
Old Nov 1, 2011 | 08:28 PM
jdub9000's Avatar
jdub9000 is on a distinguished road
Default Questions on Solid Axle Swap
im goin with a solid axle swap instead for the IFS lift kits and had some questions...
Is the Off Road Direct kit a good kit?
What is the easiest front axle to use?
Any modifications on the t-case or front driveshaft?
Old Nov 22, 2011 | 06:54 PM
oldsbravada2000's Avatar
oldsbravada2000 is on a distinguished road
You will just have to use a jeep cherokee xj front driveshaft and off road direct is about to come out with a 4 link coil spring kit that uses cherokee lift springs but for the leaf spring kit a dana 44 would work best if it is a daily driver, dana 60 is a little bit overkill because blazers and jimmys are kinda small.
Old Nov 22, 2011 | 07:36 PM
neo71665's Avatar
Axle sizing has more to deal with than just the truck size alone. Depends more on tire size. Dana 60 might be too much for a 31 inch tire but for a 37 or bigger its jsut right.
bdemutis
28
Mar 28, 2013 02:26 PM
jimmy1996
Oct 25, 2009 10:51 PM
jpkoest88
Apr 3, 2008 02:28 PM
Nightkrawler99
Feb 9, 2008 09:29 PM
sasquatchfound
Jul 15, 2007 05:23 PM
