Questions on Solid Axle Swap
im goin with a solid axle swap instead for the IFS lift kits and had some questions...
Is the Off Road Direct kit a good kit?
What is the easiest front axle to use?
Any modifications on the t-case or front driveshaft?
You will just have to use a jeep cherokee xj front driveshaft and off road direct is about to come out with a 4 link coil spring kit that uses cherokee lift springs but for the leaf spring kit a dana 44 would work best if it is a daily driver, dana 60 is a little bit overkill because blazers and jimmys are kinda small.
bdemutis
28
Mar 28, 2013 02:26 PM
jimmy1996
Oct 25, 2009 10:51 PM
