Rag Joint Trouble...
Old Mar 14, 2012 | 02:47 PM
bekowr's Avatar
bekowr is on a distinguished road
Post Rag Joint Trouble...
Ok, this one might be a no brainer, BUT, does anyone know how in the world to re-attatch the ragjoint to the steering gearbox shaft? I realize you have to remove the binch bolt completely, but do i have to spread that opening to get it on or something?
BTW, its the 2000 4wd.
Last edited by rriddle3; Mar 15, 2012 at 06:45 AM. Reason: COMBINING CONSECUTIVE POSTS
Old Mar 15, 2012 | 03:26 PM
aa21830's Avatar
aa21830 is on a distinguished road
Doing this from memory, but I believe I've used a big screwdriver or end of a crow bar to spread it apart a little. It's a lot easier if you have the wheels off the ground and you turn the key to the accessory position. First time I tried to take off the shaft, I didn't have the wheels off the ground and there was just enough tension that when I tried to put it back on, splines were off a tiny bit. Once I jacked it up and was able to turn the shaft slightly, it went right on.
Old Mar 15, 2012 | 04:16 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
I think i just used a hammer and lightly tapped it on there, but the key needs to be in the acc setting so you can move the shaft
josemateos
Feb 18, 2014 10:00 AM
Guntheone
Dec 4, 2010 05:59 PM
livinterror
Dec 28, 2008 09:50 PM
88blackzcand95blazer
Dec 19, 2008 08:13 PM
hoagmaster
Feb 1, 2008 02:50 AM
