Rear Axle Preload/Pinion Yoke Question
Old Jun 1, 2018 | 11:46 AM
LesMyer's Avatar
Originally Posted by mr.vls
When I installed the G80 I had to replace the ring & pinion gear due to carrier breaks. My crush sleeve had split and the pinion bearings were worn. I installed new crush sleeve, new pinion bearings, new carrier bearings and new axle bearings. The only way I was able to wrench the crush bearing was to use my impact gun a little at a time and check the rotational torque after each little hit with the impact gun. I was able to get the torque value right at 26 inch pounds. (I did set pinion depth, backlash and checked gear tooth pattern)
I just put a spool with new gears and bearings in my S10 after breaking the spider gears in my 8.5" Eaton disc-type Posi at the drag strip with my new trans brake. Even those somewhat larger ring gear rears are far from bullet proof. Flying pieces dinged up the ring and pinion. Going back to gether I went with a solid spacer/shim arrangement that you can buy, instead of a crush sleeve for the pinion. Have to disassemble and reassemble with shims in increments of 0.002" to get desired preload, but no 400 ft.lb torque or pinion holder to crush the sleeve. You must have one heckuva impact wrench!! My setup at home would never do enough to crush a sleeve!
Old Jun 1, 2018 | 02:42 PM
Bravada01's Avatar
Bravada01 is on a distinguished road
Originally Posted by Lesmyer
Nice photos!
As I understand the Gov-Lock rears - they do nothing unless one axle spins enough faster than the other axle that a centrifugal weight throws out a cog and the two axles lock together. No prevention of wheel slip, just sudden locking of the axles after excessive wheel slip has already occurred. This is why they are lovingly called Gov-bombs. Do this when you make some real power and they explode! Not good rear ends for people who like to spin their tires to impress their friends.
Should be good for me since my AWD Bravada only makes 190hp.
Old Jun 2, 2018 | 04:29 PM
Bravada01's Avatar
Got everything back together and put around 100 miles on the car. Working great! No vibrations either.
Old Jun 2, 2018 | 07:02 PM
LesMyer's Avatar
Good job!! Glad to hear it!!
justinh4578
Mar 21, 2013 04:27 PM
Kknd310
Aug 16, 2012 06:46 PM
alamantia
Jan 5, 2010 09:37 AM
*2000ZR2*
Aug 9, 2009 08:50 PM
chvygirl84
Nov 10, 2008 12:29 PM
