rear axle width help needed
Old Feb 4, 2018 | 03:25 PM
jkyle187's Avatar
jkyle187 is an unknown quantity at this point
Default rear axle width help needed
i want to put a zr2 rear axle in my 03 blazer...to get the rear the same width as the front...was told i can not do this unless the axles are the same ratio...can anyone chime in....and what years im looking for?
Old Feb 4, 2018 | 04:02 PM
chevyriders's Avatar
98+ zr2 should work as long as it's the same ratio.
I would recommend finding one that has a gov-loc style locker (g80 rpo)
RPO codes for gear ratio identification:
GU4=3.08
GU5=3.23
GU6=3.42
GT4=3.73
GT5=4.10
HC4=4.56
Old Feb 12, 2018 | 12:46 PM
El_Beautor's Avatar
GU4=3.08
GU5=3.23
GU6=3.42
GT4=3.73
GT5=4.10
HC4=4.56
Standard OEM gears in a ZR2 are 3.73 (GT4). The most common in non-ZR2 Blazers are 3.42 and 3.73, and you can find your OEM equipment on the RPO list sticker in your glovebox. Just find the code on your sticker that matches the list posted by Chevyriders. If you have different gears in your truck than the donor ZR2 axle, the easiest & cheapest is to just swap your front diff as well.
brunosrk
Tires and Wheels
Jul 3, 2011 10:06 PM
tony991
Tires and Wheels
Jun 24, 2010 11:55 AM
kgkern01
Sep 12, 2009 07:57 AM
robbiegamble
Feb 14, 2009 12:20 PM
Likwid
Tires and Wheels
Apr 3, 2006 03:50 PM
