Rear Brakes
Rear Brakes
I have an 02 Blazer with rear disk brakes. I need to replace the rear pads. It has ABS. Is there anything I should do different from changing the front pads? The manual dosent say if there is anything else besides using a clamp to depress the brake pistons after removeing the calipers.
Just did mine. Back is same as front.
Thank you
Thanks, I will be doing mine tomorrow.
replaceing caliper & bracket
does anyone knows how to replaced the old caliper and bracket? i need to do this and i have no idea if i have to do something specific! i replaced the old pads, but i didn't how to push back the piston so i uncreew the fluid line and now the i put the pads together the pedal is very soft and spoongie!!! help please!
You introduced air into the system when you opened the line. You need to bleed the caliper.
Anyone wishing to respond to blazzer99, please do so in the original thread he posted on this subject:
replaced caliper bracket
poertsch
04-23-2016 01:05 PM
goslats
15
07-31-2015 09:19 AM
218persuader
08-20-2010 06:11 PM
