Rear differential gear ratio identification
Old Nov 26, 2013 | 07:28 AM
rickamp's Avatar
rickamp is on a distinguished road
Question Rear differential gear ratio identification
Hello friends out there,
Glad to join u guys on blazerforum.
My cousin has just got a 1996 blazer model but we haven't enjoyed the ride as we found out the differential carrier gear have been damaged ,
We re looking on getting a rebuild kit , but our main problem is to find the gear ratio for that rear differeantial as all spare dealers are asking for it .
Would you help if you check on the car vin: 1GNDT13W1TK133395
Thanks a lot
Rick, Uganda
Old Nov 26, 2013 | 07:41 AM
richphotos's Avatar
This is the new member introduction area, not a place to ask questions, but since you posted in here, Look in the glove box for the RPO code.
And match what code you have in there with this list
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
GV1 : AXLE REAR, 2.73 RATIO
GV2 : AXLE REAR, 5.83 RATIO
GV3 : AXLE REAR, 3.08 RATIO
GV4 : AXLE REAR, 3.36 RATIO
GV5 : AXLE REAR, 3.55 RATIO
GV7 : AXLE REAR, 4.11 RATIO
GV8 : AXLE REAR, 2.72 RATIO
GW2 : AXLE REAR, 2.56 RATIO
GW3 : AXLE REAR, 2.56 RATIO
GW4 : AXLE REAR, 3.31 RATIO
GW5 : AXLE REAR, 2.73 RATIO
GW6 : AXLE REAR, 3.27 RATIO
GW8 : AXLE REAR, 4.10 RATIO
GW9 : AXLE REAR, 2.93 RATIO (DUP WITH GU3)
G80 : AXLE POSITRACTION, LIMITED SLIP
Old Nov 26, 2013 | 12:30 PM
rriddle3's Avatar
*Moved to 'Steering, Suspension, & Drivetrain'*
Old Dec 3, 2013 | 02:06 AM
rickamp's Avatar
Thanks Jimmy,
I checked and found out it was G80 now which ratio is that?
I will appreciate your response.
Rick
Old Dec 3, 2013 | 06:44 AM
chris015's Avatar
g80 is "posi-trac" not the gear ratio. the ratio should be beside where you found g80
Old Dec 3, 2013 | 09:22 AM
El_Beautor's Avatar
Most likely the gears in your truck will be one of these:
- GU6 - 3.42
- GT4 - 3.73
- GT5 - 4.10
- GU4 - 3.08
As far as I have been able to research, those are the gears that came from factory on the S-series trucks and SUV's. By far the most common were the GU6 and GT4 gears. Like Chris said above, G80 was the posi-trac locking differential and was an option with any of the gear sets.
Old Jul 1, 2014 | 08:57 PM
ktjr2's Avatar
ktjr2 is on a distinguished road
what blazers had the GV2 5.83 gears? would that be a good rearend for an ls swap?
Old Jul 2, 2014 | 10:18 AM
El_Beautor's Avatar
What size tires are you running that you want 5.83 gears? The size of your engine has a lot less to do with gear ratio selection than the tire size.
Old Jul 2, 2014 | 01:47 PM
according to your VIN
GT4 - 3.73
G80 - Limited slip
I have the ability to run them at work
dharvey4651
Mar 7, 2015 02:51 PM
BRoss99
Oct 31, 2014 03:32 PM
rkwhitted
Jul 1, 2011 06:43 AM
scrmmealuvsong22
Oct 8, 2009 01:03 PM
NC93BLAZERLT
Oct 28, 2008 07:52 AM
