rear end issues!
rear end issues!
my rear end went out in my blazer about a month ago and i put a new rear end in not the same one though and i know i should of but with this new rear end just recently there started a vibration from about 45-85 and it does it even worse it seems when your slowing down. and when i put into gear theres a clunk but no other noise after that.. could someone please help me?!
RE: rear end issues!
please do not create multiple posts on the same topic. When someone has an answer, they will post up.
My post is right below your I to am experiencing the same clunk when shifting into forwardor reverse and I get a clunking type noise when shift into second especially when it has set over night after ithas warmed up it gets a little better but still noticable. I check and changeallfluids like clock work. I was told it could be the rear u-joint as they oftenfail more than the front but I checked them and they were fine. Hope somebody can help us with this and also myother listed in 4x4 2 hi switch acting weird problem.
sorry it didnt show up in the other one so i figured i didnt click the post thing.. my bad.. and my blazer is a 2wd
I have the same problem in my 89 a bad "clunk" when putting in gear or changing directions I have changed the U-joints and had the rear cover off the R&P look fine and the "Slack" is somewhere in the carrier/posi unit . Is there a simple fix?
I'm getting confused with 3 guys posting their problems in the same thread!
A vibration at speed could be caused by u-joints, driveshaft out of balance, loose pinion gear or wheel balance.
A clunk when going forward to reverse or park to drive could be worn u-joints, backlash in the diff (slack between the ring and pinion gears), slack in the transmission or transfer case.
brino1
02-25-2011 08:05 PM
johnnyb
11-06-2007 02:41 PM
