Rear end maintenance
Old May 13, 2012 | 10:15 PM
r0k0's Avatar
r0k0 is on a distinguished road
Default Rear end maintenance
Hey guys, i'll be swapping out the lea spring and bearing soon,
which oil is best for the rear diff and G80 limited slip ?
whats the quantity of the oil + limited slip addictive ?
will OEM or OE Replacement shock take the extra 2.5" lift from shackles ?
should i change the u-bolt at the same time ?
how hard is it to replace a broken stud ?
anything else i should be looking for when im underneath there ?
Thanks
Old May 17, 2012 | 07:38 PM
r0k0's Avatar
no one has any suggestion ?
Old May 17, 2012 | 08:09 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
Best oil is 75w90 AC Delco synthetic, that is what GM recommends
3L will be enough to fill it and no additive required with the Delco fluid
OEM shocks wil handle a lift shackle for ON road use only
Normally if you loosen a u-bolt you replace it, but they can be re-used from time to time
Broken Stud? You mean wheel stud? Knock it out with a hammer and draw the new one in with a stack of washers and a wheel nut
Old May 20, 2012 | 06:37 PM
r0k0's Avatar
no need for rear axel removal for removing a broken stud ?
Old May 21, 2012 | 04:50 PM
Jase1979's Avatar
nope leave the axle right in there
Old May 21, 2012 | 08:39 PM
r0k0's Avatar
kk thought it was harder, still gotta take them out so i can change the bearings, is there 2 of 4 total bearing in the rear axels ?
Old May 22, 2012 | 03:56 PM
Jase1979's Avatar
There is 1 bearing on the end of each axle tube behind your axle seal, then there is 2 bearings on the differential carrier, and 2 more bearings on the pinion gear, all bearings are pressed on and off, and remember if your changing more then the outer axle bearings then you are supposed to re shim the rear end for proper clearances
Old Jun 15, 2012 | 10:07 PM
r0k0's Avatar
http://www.ebay.ca/itm/370614298246?...84.m1423.l2649
is this the perfect thing to buy to redo the rear diff ? all the stuff is included
Thanks !
chipjumper
15
Dec 14, 2019 08:49 AM
doktornasty
Nov 3, 2013 03:12 AM
brino1
Feb 25, 2011 08:05 PM
Canadian88
Oct 1, 2006 10:12 PM
black19
Feb 1, 2006 11:02 PM
