rear end noise
Old 03-27-2009 | 04:09 PM
jester429's Avatar
jester429 is an unknown quantity at this point
Default rear end noise
So I just noticed a 'click click click click' sound coming from the rear end of my 96 blazer 4x4 when The rear wheels are moving. Drive shaft is secure. any ideas? I know it's rather vague description but I don't know how else to describe it.
Thanks,
J
Old 03-27-2009 | 04:17 PM
Swain's Avatar
Swain is an unknown quantity at this point
Are you hearing this while driving or have you jacked the truck up and listened? First make sure there aren't any rocks in you tires they can make weird sounds sometimes, next after raising the vehicle and supporting it securely have someone put the truck in gear and check for the noise. Could be a bad bearing on either axle, which are very easy to replace.
Old 03-27-2009 | 04:40 PM
jester429's Avatar
I had the blazer jacked up and was hearing the sound. Would a u-joint also be a possibility?
Old 03-27-2009 | 05:26 PM
Swain's Avatar
Could be check the driveshaft for play around the u-joints.
Old 03-27-2009 | 11:36 PM
jester429's Avatar
Angry
I think the rear end is TOAST! Went to go pick up a new set of u joints, turned out of the parking lot at my place and BANG! so I stopped. Looked under the rig, everything was intacted. Started moving again at less than 5 mph and BANG BANG BANG BANG BANG,,,,don't think it's the u-joint now. rear end at the local wrecking yard are 450 bucks....
Old 08-27-2009 | 10:42 AM
jsmz's Avatar
Banned for childishly attempting to delete all his posts
jsmz is an unknown quantity at this point
well, you have a 96 so i really doubt your rear end is that much money at the junk yard.
i can go to any junk yard within at least 100 miles of me and pick up a 98+ rear end with disc brakes for $180.. a drum setup for even less.
also, just to be a dick i see in your sig that you think your blazer has a 4.7L. why are you here if you dont even know what size your engine is.
Old 08-30-2009 | 09:13 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
****. Rearends in these are a breeze to rebuild with the correct tools and a little bit of knowledge. Just did my first a few months ago and it went without a hitch.
Old 08-31-2009 | 12:49 PM
Bberry20's Avatar
Bberry20 is on a distinguished road
Just throwing this out there but my rear end did the same last weekend and i cant find a rear end for any less then 500. So JSMZ if you could get me one for a 99 for 180 let me know i would love to get one that cheap!
Old 08-31-2009 | 01:08 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
check out this site http://car-part.com they have have 3.73s with g80 or without for around $100,obivously it all depends on how close you are too them though if they are possible for you since you dont ship axles via ups.
Old 09-03-2009 | 01:43 AM
jsmz's Avatar
here is where i get all my local prices from. very handy website.
http://www.partshotlines.com/
Quick Reply: rear end noise
