Rear end sway
Old Oct 3, 2010 | 01:29 PM
scottspeer's Avatar
scottspeer is on a distinguished road
Default Rear end sway
Just bought a 99 LT with 120k on it. When driving at any speed and road becomes slightly uneven or has a dip, vehicle seems to bounce a lot and rear end seems to sway. Before I bought it, it had new idler and pitman arm put on and I think front end needs aligned, but like I said earlier, seems to be swaying in the rear. Doesn't seem to be a lot of body roll in corners. What is causing the sway?
Old Oct 3, 2010 | 03:01 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
I had a similar issue. When the car dipped it would seem to sway and dip in hte rear. I replaced many parts, ball joints, sway bushings, idler arm and so on. It finally settled after a front end alignment.
Old Jan 9, 2012 | 07:44 AM
shotnva777's Avatar
shotnva777 is on a distinguished road
Front end alignment 'should cure it. Check bushings on rear sway bar?
habafab
Mar 13, 2013 06:59 AM
brino1
Feb 25, 2011 08:05 PM
Bad Ramer Jamer
Sep 12, 2008 06:55 AM
samurai_24
Sep 26, 2007 09:22 AM
