Rear end yoke issue
I've got a 85 Blazer full size. That I'm getting from my bro-in-law. He broke the rear drive shaft a while back and in the process tore the rear end yoke up. Here's the kicker he has misplaced the old tore up yoke. He took it to a place to order a new one and left it with them. He then ...uh... had some issues and never went back to get the new one or the old one. The blazer has a 305 with a 4spd trans. I remember that the old yoke had the little teeth on it were the u-joints sit. I can't seem to find one like it. I even work at a salvage yard and can't,lol. Now can I use any 1/2 ton fullsize yoke? even if it doesn't have the teeth, as long as it matches up with the driveshaft? Do I need to count splines or anything?
Any help is greatly apreciated!
You will have to match up the spline count with that of the pinion shaft that is in your rearend. I'm not sure what you mean by teeth though... I have never seen a yoke that had 'teeth' where the u-joint cups would sit.
LOL I hadn't seen one with the teeth before he broke it either. I did find a couple others with teeth on them after he broke it but the weren't the same width, if I remember right. He seemed to think the teeth were there to hold the u-joint cups in place. I thought the cups just sit there and were held in place by the "straps" that hold the driveshaft to the yoke. I should be able to use any 1/2 ton rear end yoke as long as the spline count is correct and it matches up the u-joint width, correct?
Yes. You may also want to verify the lip seal surface diameter between the two rear ends.
Awesome. I'll make sure I check the seal size. Thanks a bunch for the help!
iamchevyman5
12-28-2011 01:52 PM
old skool luvr
11-09-2009 10:28 PM
