Replacing tie rods- length, spacing concern
Old Dec 14, 2014 | 04:08 AM
GunsOfNavarone's Avatar
GunsOfNavarone is on a distinguished road
Default Replacing tie rods- length, spacing concern
Replacing the tie rods, both inner, outer and sleeve on a 98 S10 ZR 2. All was going well except when I place the replacement assembly next to the original assembly, one the replacement assembly the spacing inside the sleeves seems to wide and I am thinking should be somewhat centered. A picture describing the condition is attached.
Hoping forum members can take a look and share what right should look like.
Attached Thumbnails Replacing tie rods- length, spacing concern-tie-rod-old-replacement.jpg
Old Dec 14, 2014 | 07:00 AM
newguy's Avatar
I would think that as long as the clamp on the sleeve makes full contacted with the threaded section of the tierod, you should be fine
Old Dec 14, 2014 | 04:33 PM
The two main things to pay attention to are:
#1 The distance from center to center of the grease fittings is equal to the old assembly that you are replacing.
#2 That the gap between the ends is approximately centered in the sleeve.
The alignment shop will make the final adjustment to them.
Old Dec 15, 2014 | 04:25 AM
Thanks, appreciate the time to reply.
Cassera
Aug 15, 2014 06:59 PM
Yooper
Jul 26, 2009 03:01 PM
Stillafordfuy
Feb 21, 2009 11:44 AM
bertrenolds
17
Dec 30, 2008 03:30 AM
rustynail
Jun 29, 2008 03:48 AM
