ring and pinion help
hello guys, i have a 88 s15 jimmy it was 4wd untill i took out the frount diff. i just put on smaller tires becouse im lowering it i uses p205/50r15 on stock alum. 4+4 rims. doing this lowered the truck about 4in. but now the shift points are all roung. now what i need to no is can i just change the ring and pinoin to get it back(or close) to what it was?? if so what do i need to now before ordering a set?? the truck has a modified 2.8l engine with a 700r4 trans. how wouild i no what ring and pinoin to get?? thanks guys please help.
ps i do not want the stock tires on it i like the small er tires just need to get my shift point back were they were.
thanks for replying, the stock tires were 235/75r15. as for the code i looked and did not find any gu codes. i looked on the diff. cover thinking there my be a tag with this info. on it but no luck. i dont no what to do.
can somebody explane what say a 4.10 gear ratio means?? or say 2.73. im trying to figure out would i need to slow the pinon down or speed it up? thanks.
4.10:1 means that the pinion rotates 4.10 times for every 1 revolution of the ring which means that for every 4.10 revolutions of the driveshaft, the wheels turn 1 revolution.
For 2.73:1 gears, just substitute 2.73 for 4.10 in the sentance above.
Attached is a snip from the '88 RPO code list. Looks like back then there was either GT or GU utilized for the s-series gear ratios.
[IMG]local://upfiles/667/F68665C9C0F9427DA50643C383303301.gif[/IMG]
marksoftball
Sep 20, 2011 03:58 PM
alesv
Apr 12, 2010 11:21 AM
