round and round a squeek
Old Jun 16, 2009 | 09:23 AM
deadbuzzard's Avatar
deadbuzzard is an unknown quantity at this point
Default round and round a squeek
So recently I have noticed a squeek. Im guessing it has something to do with the revolutions of a wheel. I can hear it when im only moving and its like eeeh eeeeeehh like you would hear with an old small windmill when it spins.
What is it? Something I need to fix pretty soon?
Old Jun 16, 2009 | 04:59 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
does it sound like you have huge mud tires on? if so i would think it could be the wheel bearings, but thats more of a whine sound than a squeek.
Old Jun 16, 2009 | 05:34 PM
Boyer2011's Avatar
Boyer2011 is an unknown quantity at this point
does it make this sound when you turn bcuz when i turn sometimes ill hear a whine and i believe its a wheel bearing in my front
Old Jun 16, 2009 | 09:14 PM
If it is a squeaking sound, it is likely one of your brake pads. I would inspect the brakes first and foremost. See if you can repeat the noise with the front end off the ground.
Old Jun 17, 2009 | 01:44 PM
i think swartikk is right although i havent had time to check them
it has been really rainy if that helps
Old Aug 5, 2009 | 02:39 PM
ok... i have checked the brakes and had les schwab check. They are good... Although i kinda hear a noise while driving ... kinda a whir or something but only when the revolution reaches a certain point. but no more squeek while driving forward.... now it switched to when i go to revearse it is a really loud squeek.. like metal on metal. (no the brakes arnt pressed either.) what is it?
Old Aug 5, 2009 | 03:17 PM
oktain's Avatar
I had a similar problem... My parking brake was seizing up on me. When I got the brake jobs done I just told them to replace anything that needed it. Squeek gone... It sounded like a metal on metal screech just like you're describing. I don't think it's the cable as much as maybe your adjuster?
Kyle, can you confirm? I'd feel a little more confident in giving him this info.
Old Aug 5, 2009 | 03:23 PM
bandidolenny's Avatar
I have had u-joints make metallic squeaking noises before.
Old Aug 5, 2009 | 03:34 PM
when going forward it the noise happens once per rev so like something is catching it.
membercalendars.com
Oct 18, 2010 08:15 PM
TripleBlackBlazer
Sep 26, 2007 03:53 AM
Mark
Aug 30, 2007 06:27 PM
haloboy99
Feb 23, 2006 09:03 AM
mkatts
Sep 6, 2004 10:54 PM
