s10 tranfer case
Old Nov 29, 2015 | 09:20 AM
57willys's Avatar
57willys is on a distinguished road
Default s10 tranfer case
89 s10 tranfer case input bearing retainer where do i find this part alot for the jeep will it work on mine
Old Nov 30, 2015 | 03:27 AM
Rusty Nuts's Avatar
The first place I would look is a transmission shop or a junkyard. I would stick with a GM donor to be on the safe side. I just replaced the seal in mine. Recommend replacing the seal before installing the T-case.
The reason I'm posting is to make sure it's oriented correctly when you install it. There may be an oil hole between the top two bolt holes in the case and a divot in the retainer to oil the bearing. If the retainer is clocked wrong when installed, it will block off that oil port. Sorry if I'm repeating something you already know.
rob1621
Feb 7, 2009 11:51 AM
Blazin_1t_up
15
Sep 8, 2008 11:45 PM
huds
Dec 2, 2007 08:37 PM
timmytenspeed
Nov 22, 2007 12:39 AM
KiddBlazer1983
May 29, 2006 12:59 PM
