safer than t-bar crank?
Old Nov 18, 2007 | 06:58 PM
davtak's Avatar
Default safer than t-bar crank?
I was checking these out on ebay and was wondering if anyone thinks that these are a better idea than a t-bar crank to level the front of my blazer with the back. I don't know the amount of difference, all I know is that the front is lower than the back just by eye. I have heard that a t-bar crank increaes the wear on the suspension and you have to get an allignment. They sound better, but I wanted to get another opinion. They also come in 1-inch also. These are 3/4 inch spacers.
ebay clicky
Old Nov 18, 2007 | 07:16 PM
Default RE: safer than t-bar crank?
2WD only... They are spacers for on top or bottom of the coil springs on a 2wd truck. Won't work for a 4wd.
Old Nov 18, 2007 | 08:03 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Yep, no worky for 4x4, otherwise I would have gotten those in an instant. Pretty much its just a t-bar crank for us or going all out with a 6" suspension lift.
Old Nov 18, 2007 | 09:14 PM
davtak's Avatar
Oh, ok. Well then, what is the max I can go with a t-bar crank and not have to worry to much about my suspension going too soon. I measured it with my fingers and it seems like it is about a 1/2 to 1' difference. What is the # of cranks to inch lift ratio? Or do I just go one turn at a time and just measure after every turn? I want the front to be level with the back for when I get the wheel spacers so it doesn't look a little awkward.
Old Nov 19, 2007 | 12:29 AM
thegr81's Avatar
I would say lift spindles to maintain front end geometry but I can't find any!!
Old Nov 19, 2007 | 12:40 AM
mdehoogh's Avatar
i did about 3.5 on the pass side and 2.5 on the drivers side. people say its 1turn=.25" lift but my truck went up about an inch on the drivers side and about an inch and a half on the pass side (uneven side to side).
a lot of it depends on how worn the tbars are. it would probably be a good idea to measure often while youre lifting. that way, you wont "overlift" it.
Old Nov 19, 2007 | 04:40 PM
YepIOwnA97Blazer's Avatar
YepIOwnA97Blazer is an unknown quantity at this point
usually .5" to 1" they say is pretty safe and won't wear much more than stock, someone confirm this; since i havent cranked mine yet (waiting to get my BL installed)
Old Nov 19, 2007 | 04:47 PM
cliro's Avatar
cliro is an unknown quantity at this point
the 4x4 lift place in town here told me 1" is safe.
Old Nov 19, 2007 | 07:02 PM
davtak's Avatar
Cool. I think that should even it out a bit. Thanks cliro
Buddykitchen
Dec 10, 2016 06:37 PM
g_mike
Aug 22, 2010 02:46 PM
DreadPirate_Davey
Lifting Tech
Dec 21, 2009 06:13 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
