Shackles
Old Dec 22, 2009 | 05:41 PM
Qumodo's Avatar
Qumodo is on a distinguished road
Default Shackles
im looking to get a set of shackles for my 1989 s-10 blazer 4x4. anybody know of a good set? i figure with the shackles and cranking the tbar i should be able to get 31" tires in there.
also do shackles only raise the rear? or do i just buy 2 sets in order to raise the front as well?
Old Dec 22, 2009 | 06:30 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
they just raise the rear only. the tbar crank is what lifts the front end. As far as the shackles go i dont know what the guys here got, i made my own (not sure of the dementions right now tho). I think you might find them on ebay for around 80$ for a set.
leeclark's Avatar
oh and tbar and shackles is what i did to my blazer and got 31x10.50s on it. mine is a 2nd gen tho but i'm sure it will be the same for 1st gen
Old Dec 22, 2009 | 06:54 PM
Qumodo's Avatar
so if i get 3" shackles to get 1.5" lift how many turns will i need to crank the tbar to keep it level?
Old Dec 22, 2009 | 07:51 PM
leeclark's Avatar
for every 1" of lift you need to make four complete turns. i dont think you can go above 2 inches tho. i got 2" shackles and did about 1.75" in tbar crank and it evened it out nicely. you can look at my profile pics
Old Dec 22, 2009 | 08:08 PM
Qumodo's Avatar
lee where did you get your shackles from?
Old Dec 22, 2009 | 08:26 PM
ABN31B's Avatar
shackles right here: here are 219 threads on shackles
search will have everything you need to know about shackles.... EVER
Old Dec 26, 2009 | 07:42 AM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Here is what my 88 looked with a 3 inch body lift and 31 mud terrains. I wouldn't crank the tbar too much on these older trucks unless you have newer front suspension parts. Could cause a lot of wear.
https://blazerforum.com/forum/lifting-tech-44/finally-found-my-old-pics-my-blazer-after-lift-38380/
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
moose4553478
Lifting Tech
Oct 24, 2009 12:41 AM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
