Which size sway bar bushing?
Old Jan 23, 2010 | 10:44 PM
ned4spd8874's Avatar
ned4spd8874 is an unknown quantity at this point
Default Which size sway bar bushing?
While looking at my ball joints that need to be replaced, my neighbor noticed that the sway bar bushing is not looking good and should be replaced too. When I went to the auto store to get all the parts, they asked me what size the bushings are. They had like 4 of them in the computer. I'm not sure what size mine are? Any input out there for this? Thanks!
Old Jan 24, 2010 | 01:38 AM
old skool luvr's Avatar
yeah, take a dial caliper (or a tape measure) and just measure it.
Old Jan 25, 2010 | 12:37 AM
jaybird33081's Avatar
jaybird33081 is on a distinguished road
I had same problem. I ended up buying both sizes for my truck then returned the ones that were to small. but i cant remember off the top of my head which ones i used. i think it was 33
Old Jan 25, 2010 | 12:23 PM
ABN31B's Avatar
i did the same, order the 28mm thinking that was standard (zr2 is 33mm) but got screwed out of my $3 when i had to go to Car Quest and get a set of 30MM bushings (hence the red bushing/blue link )
the point here is: Measure first
Old Jan 25, 2010 | 06:31 PM
neo71665's Avatar
Easiest way I've found to measure them if you don't have a caliper (you should really buy one) is to take a crescent wrench, tighten it down on the sway bar, carefully pull it off without messing with the adjustment, and finally measure the gap between the inside jaws.
Tajohns34
Jul 10, 2014 02:02 PM
lizardking88mph
Aug 5, 2011 12:12 PM
sedatedbylife
Nov 9, 2010 07:39 PM
jstein
Sep 5, 2010 09:08 AM
fondo
May 17, 2010 03:13 PM
