steering shaft upgrade
Old 09-22-2020, 12:38 PM
richards2004's Avatar
richards2004 is on a distinguished road
Default steering shaft upgrade
read somewhere that the grand cherokee steering shafts work for 04 blazers. if this is true who has done it.. whats the reasoning behind it and what year grand cherokees should be used for donor...
Old 09-22-2020, 02:37 PM
It eliminates the "rag joint" at the steering box and replaces it with a "real" u-joint. It's easier, IMO, to just buy a replacement u-joint for the stock shaft from Flaming River or another aftermarket manufacturer.
Old 09-22-2020, 03:23 PM
"You would have to measure the shaft. If it is a DD shaft measure on the round ends. If you have a spline shaft, measure the diameter and split the shaft in half and count the splines then double the number to get the complete count."....... This is what i was told in order to order a U-Joint
Old 09-22-2020, 06:41 PM
This the Borgeson joint I used. If you do a quick search, it should be pretty easy to find a part number for the Flaming River joint, as well. Or you can use any joint with a 3/4" 30-spline on one end and 1" double D on the other.
Old 09-22-2020, 09:18 PM
2001ZR2's Avatar
I used the flaming river to upgrade my truck and am really happy.
I chose it because the reviews on here and S10 forum but you can get one much cheaper
I don't paid as much as it is today but am happy.
Here's an amazon link
Amazon Amazon
Old 09-23-2020, 05:08 AM
so the whole idea is to get rid of the coupler at the end which in point makes for a tighter feel for steering. because that is what i am experiencing. the alignment is good all brand new front end parts and i mean all. and steering is still a little off center so im thinking its either in the shaft or gear box. redcap gears said they have them in stock... never heard anything about them though since i dont know anyone who would use them. so if im going to keep the blazer why not be all new...
Old 10-04-2020, 06:41 PM
2004 Blazer ZR2's Avatar
2004 Blazer ZR2 is on a distinguished road
I just purchased the lower steering shaft that uses the factory upper shaft from Hooker (71223021HKR) 94-04 GM S10 steering shaft.
dbsens83
07-20-2014 07:05 PM
gary h.
01-14-2011 09:57 AM
MLRS327
09-30-2010 08:45 PM
SniperX13
03-16-2006 09:57 PM
Bigjoey71
Suspension Tech
01-03-2006 12:28 AM
Quick Reply: steering shaft upgrade
