Steering wheel clicks
I have a click that happens when I turn the steering wheel in either direction. It is multiple clicks. For example if I turn the steering wheel to the right or left 45 degrees I will probably get 5-10 clicks.
This happens with the car running and not running.
I followed the shaft down on the inside to the firewall and it seems to be right in that area.
I could be imagining this but it seems to have started right around the time I replaced my front left hub assembly. Now that I think of it, when jacking the truck up and spinning the tire I just replaced the hub assembly on there is a clicking sound there as well. Could I have damaged something when replacing the hub or possibly it is not seating correctly?
I can feel the clicks in the steering wheel but the actual cause seems to be originating down just past the firewall. Atleast when following the shaft to the firewall I seem to be getting closer to where it is coming from. The steering lock still works just fine.
Could ball joints be causing this, even though it happens with small movements of the steering wheel with the car off?
MetalMan390
Jan 17, 2010 06:20 PM
nyege2
Jul 13, 2009 08:52 PM
huntjock
Apr 11, 2008 02:12 PM
JBacker
Dec 11, 2006 10:33 AM
