Stuck Lower Ball Joint Removal
Old Apr 16, 2019 | 08:01 PM
423CV23's Avatar
423CV23 is on a distinguished road
Got it out. That was ridiculous. Went through about 6 more drill bits. Even after the remaining piece of the ball joint was out, one of the rivets still wouldn't budge!
Had to drill all of them out from the bottom, which sucked; barely enough room for the drill under it. Once I found a decent 1/8" bit in the bulk pack I bought, it drilled through nicely.
For anyone in the future referencing this, load up on the 1/8", 3/16", and 1/4" bits. If you think 1 pack of 5-7 each will be enough, buy 3!
423CV23's Avatar
Thanks all for the advice!! Looking forward to doing the driver's side. (NOT!!)
Old Apr 16, 2019 | 08:15 PM
cleburne red's Avatar
Well, at least from this point on, they'll be bolted in, and a piece of cake to change!
Old Apr 16, 2019 | 10:32 PM
odat's Avatar
Hopefully that was just a isolated case - I have never had that much trouble and have always been able to pop the rivets out with a punch after the rivet head was removed - However I don't air chisel the heads off I zip them off with my 4.5'' hand grinder.
Best of luck
Old Apr 19, 2019 | 12:01 PM
423CV23's Avatar
Did the driver side last night. Still had to drill the lower ball joint rivets, but only from the top, maybe 1/4" deep; just to get enough out of the control arm mounting holes. Three of them began rotating slightly as I was chiseling them, so I figured it would be an easier go than the passenger side. Took about 2.5hrs total to replace the ball joints and shock.
Hopefully no issue with the upper ball joint. I load them up with some grease prior to putting a load on them. The upper was leaking grease around the top flange. Hopefully once I get a load on it, it will seal so I can fully lube it.
gocart879
Mar 28, 2018 11:32 AM
davis_larry17
May 2, 2013 05:11 PM
apaplayer
Apr 8, 2013 08:45 PM
ryanpraski
Nov 17, 2010 08:13 AM
snowboarder6899
Jan 12, 2008 04:58 PM
