Suspension leaning
Old Jan 15, 2013 | 12:26 AM
Twip's Avatar
Originally Posted by Captain Hook
Edit: Certain BMW's require 200 pounds in the driver seat during a wheel alignment. Blazers being a better quality vehicle, don't require it
lovin it!!
Old Jan 15, 2013 | 10:43 AM
tmac4t4's Avatar
tmac4t4 is on a distinguished road
when i measured i measured from the ground to the fender, before and after tbar crank, on level surface
Old Jan 15, 2013 | 03:07 PM
Originally Posted by tmac4t4
....i measured from the ground to the fender, before and after tbar crank, on level surface
That's fine if you're looking for body alignment problems, but NOT for chassis ride height, 2 totally different things. The suspension doesn't care where the body is. Adjusting front chassis ride height will affect body height, but body height has no effect on chassis ride height. If front chassis ride height is off, adjust it with the torsion bars. If the body is crooked, take it to a body shop
Front chassis ride height is the vertical distance between the lower-most inboard point of the steering knuckle, nearest the ball joint, to the center of the lower control arm pivot bolt.
1996 & newer:
4WD (except ZR2) = 4.6” to 5.0” (4.8” is preferred)
ZR2 = 4.6” to 5.2” (4.9” is preferred)
Very easy to do: Measure from the knuckle straight down to the ground. Then measure from the center of the lower control arm bolt straight down to the ground. Then subtract the knuckle to ground measurement from the control arm bolt to ground measurement. The answer, (remainder) is front chassis ride height.
Old Jan 15, 2013 | 03:31 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
What about your body mounts?
Old Jan 15, 2013 | 03:37 PM
Exactly my point, good call!
Old Jan 16, 2013 | 10:39 AM
tmac4t4's Avatar
thanks for the tip ill check my body mounts and try re adjusting according to specs and see what happens
BubbaBrooks
Nov 16, 2011 03:57 PM
air1axg
Lifting Tech
Feb 13, 2011 10:16 PM
jcon82
Lifting Tech
Mar 14, 2009 07:49 AM
j_dock69@hotmail.com
Lifting Tech
Feb 11, 2009 09:30 PM
quontush
Mar 30, 2006 01:28 AM
