Suspension Worry
Old Jun 18, 2014 | 10:51 AM
DiamondLion's Avatar
DiamondLion is on a distinguished road
Default Suspension Worry
I've got a 2001 GMC Jimmy Diamond Edition and the suspension on it is real loose and wobbly. It also creeks a hell of a lot when I'm driving. Do you think I need to get it replaced or is there a semi-cheap fix for it?
Thanks.
Old Jul 15, 2014 | 03:03 PM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Define loose...Is it loose in the steering such as a tie rod/centerlink/ball joint issue? Or is it rough when hitting bumps such as a suspension(shocks/spring issue)? Also is it 4wd or 2wd? Is the noise coming from the front or back. Need to be as descriptive as possible so we can help! To start jack the front of the vehicle up and support it so both tires are off the ground(make sure you chock the rear wheels). Now have shake the front( dont go crazy just a slight shake) tires side to side. If you feel any movement have someone else shake it and watch and see what moves. Typically this indicated a tie rod issue. Now shake the tire up and down( put one hand on top of tire and one on bottom and shake) if you feel any movement this could indicate a wheel bearing issue(especially if it moves and pops when you shake it both ways. Examine your shocks and see if you see any oil coming out of them. There are a ton of different things that can go bad and cause noise.
Old Jul 16, 2014 | 09:54 AM
Fletch,
My steering is fine. But when I hit bumps, my whole body kinda sways. I have a 2001 4x4 Diamond Edition Jimmy. As soon as I can, I will take a look at it and see if I see anything.
Old Jul 19, 2014 | 11:13 AM
tracedumashsog's Avatar
tracedumashsog is on a distinguished road
fletch, I have some front end noise, and am fixing to post about what all I have done, and what it is doing, but I am reading other post first to see if I can find an answer, and I saw what you said about having the front end off the ground, do you have to have both tires off the ground? or will the side in question do? if it has to be both, that may be the answer to my delima. I have a 2000 Bravada
EricR
Sep 9, 2011 09:34 AM
blazerguy64
Suspension Tech
Jun 21, 2005 04:46 AM
95chevyflames
Suspension Tech
May 8, 2005 07:20 PM
Hypersona
Suspension Tech
Jan 21, 2005 08:37 PM
01xtreme
Suspension Tech
Sep 14, 2004 04:31 AM
