Suspension Tech Have a question about modifying your suspension? Ask it here.
Suspension with Trailer
Old Feb 8, 2005 | 02:28 AM
blazerguy64's Avatar
blazerguy64 is an unknown quantity at this point
Default Suspension with Trailer
Hey All;
I have a 2000 4DR 4WD. I am pulling a 26' Trailer. I have a suspension problem I think. Without the trailer, my truck seems to ride lower in the back. With the trailer, there is obviously a drop. Is there a lift system that I can get that could be activated from the inside of the truck that would automatically level the truck when there is a load on? Also with the drop even without the trailer, does it sound like I would need to install new shocks, or additional leaf springs? If new shocks, what kind would be best?
Old Feb 9, 2005 | 12:44 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Suspension with Trailer
shocks do not affect your ride height at all. if the rear end is sagging, then it would be the springs. all shocks do is dampen the energy of the springs. Air Lift sells exactally what you are looking for. its airsprings that you mount in between your frame and spring pack. there is a compressor which you turn on with the flick of a switch from the drivers seat and you can level out the truck that way. when you take the trailer off, hit the switch the other way and the air will dump out the bags and bring the rear back down. hope this helps.
Old Jun 21, 2005 | 04:46 AM
BOSTONGEORGE's Avatar
BOSTONGEORGE is an unknown quantity at this point
I'm also wondering how will my ZR2 will react this summer with the trailer on. Last years I used my Wrangler 4.0 (manual transmission) and it was great, like not even having the trailer behind!
I guess it will not be as easier since my ZR2 has automatic transmission, especially when using brakes and accelerating. Any advice?
(consider the trailer with the boat on is about 2000 kg which is about 4400 lbs)
Bye,
BOSTONGEORGE
jdpilot
Feb 25, 2007 02:26 PM
ShadowHawk
Dec 9, 2006 12:52 AM
The Franchise
May 31, 2006 12:28 AM
Rups63
Apr 7, 2006 11:14 AM
trapper_canada
Aug 15, 2005 11:33 PM
