Swapping out Axles
Old Mar 28, 2010 | 10:34 PM
danmcph's Avatar
danmcph is on a distinguished road
Default Swapping out Axles
I have an '86 Blazer
I want to run bigger tires (33's) with a vehicle that will be pretty loaded down. So I want to put stronger axles under my rig.
Are their any axles that bolt right up that are stronger? I would prefer to have some axles that are a little wider if possible.
What vehicle should I be looking for to take the axles off of?
Old Mar 29, 2010 | 12:29 PM
I hope you have a fullsize. If so, it is relatively easy to get those tires to fit. You can run 33's on the stock 10-bolt axles. Any larger and you may have problems.
As far as upgrades go, you can get a Dana-60 out of a 1-ton for the front and a 14-bolt full floater rear axle from a 3/4 ton for the back and you'll be strong enough for some pretty big tires. You can also get the 14BFF from a 1-ton, but the spring perches will need to be cut off and moved because the spacing is different on a 1-ton than on a 1/2 or 3/4-ton.
BTW, please put your vehicle information in each post requesting help. You can do this either by creating a garage (link in the top menu bar) for your truck, by putting this information in your signature (via your User CP) and attaching it to your posts, or by including it with each post for help.
Old Mar 30, 2010 | 09:04 AM
danmcph's Avatar
This is a full size blazer. I put the info on it in the "Garage"
Old Mar 30, 2010 | 12:47 PM
abig84's Avatar
Yep common swap is a 14bolt/dana 60. They will be a few inches wider but not much
Old Apr 2, 2010 | 02:06 PM
danmcph's Avatar
I just found a dana 44 front and a 14 bolt rear from a suburban made in the 70's.
How good would these be?
Are they wider than the blazer axles?
Old Apr 2, 2010 | 07:01 PM
danmcph's Avatar
Does anyone know?
cali bear 87
Nov 17, 2012 05:02 PM
shotnva777
Sep 10, 2011 01:14 AM
litterbug
Aug 25, 2011 11:18 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
Blade69
Engine & Internal
Apr 30, 2005 08:37 PM
