Sway bar bushing removal/installation
Old May 14, 2010 | 08:53 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Sway bar bushing removal/installation
I was thinking about changing out my sway bar bushings to see if it will correct the light clunking noise coming from the front driver side (I think). Is it necessary to unload the torsion bars to change these bushings? I hope not cuz its a PIA to do. Just to be sure, the sway bar doesn't affect alignment, does it? The tire on the driver side is wearing more on the outside and I'm not sure why. Since owning this truck ('08) I've replaced the steering linkage, ball joints, control arm bushings, and the DS hub and axle. Mostly with high quality parts. Any suggestions?
Old May 14, 2010 | 09:27 PM
AJBert's Avatar
You do not have to remove the tension on the tbar to remove your sway bar.
Old May 15, 2010 | 01:33 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
I did mine one side at a time with the truck on the ground. IIRC, the suspension needs to be loaded when you tighten everyting up. It's a simple job that should take no more than an hour, depending on which bushings you're replacing. If it's the end links, about an hour. The frame mount bushings took me like 15 minutes or so.
Old May 17, 2010 | 03:13 PM
fondo's Avatar
Thanks
jim baird
Nov 9, 2013 07:04 PM
lizardking88mph
Aug 5, 2011 12:12 PM
sedatedbylife
Nov 9, 2010 07:39 PM
jstein
Sep 5, 2010 09:08 AM
ned4spd8874
Jan 25, 2010 06:31 PM
