Taking out the rear axle: Questions
Old Jan 6, 2010 | 05:48 PM
smurphy132's Avatar
smurphy132 is on a distinguished road
Default Taking out the rear axle: Questions
New to this forum, I couldn't find anything on it but I have a couple questions on it.
As I was doing the rear brakes on my 96 Blazer (4x4, 4 door) one drum looked really oily. My initial thoughts were brake line, or wheel cylinder. I looked at each, no problem. As I moved the axle I noticed it had alot of give, more than the other side. There we go: Bearings gone, needs new bearing and seal.
To take the axles off, I have to take the cover off the gears. Is there any special tools, any heads up, or any other things I have to know before I start this job. Any help is greatly appreciated.
Old Jan 6, 2010 | 07:14 PM
old skool luvr's Avatar
what did you mean by, "As I moved the axle I noticed it had alot of give, more than the other side. There we go: Bearings gone, needs new bearing and seal."? which way did the axle move? in & out is normal (to a certain degree). any radial movement, which i've never seen (or done-and i've broke alot of stuff), is definately not good.
as for what you need to do to complete this job, you could look HERE, or just do a search on rear diff's. it's been talked about alot.
higgy
Nov 29, 2009 03:09 PM
eastsiderides
Mar 28, 2009 03:20 AM
runnin blazer
Nov 17, 2008 02:29 PM
slickster01
Jul 22, 2008 07:48 PM
ivannj
Engine & Internal
Jan 20, 2006 10:52 PM
