Tire Wear
Old Mar 19, 2009 | 10:35 AM
Iceman991's Avatar
Iceman991 is on a distinguished road
Default Tire Wear
I put new Firestone Destination tires on My 97 Blazer 30,000 miles ago and already the outside edges on all tires are worn slick. Is this an alignment problem or something to do with shocks/suspension? Thanks.
Old Mar 19, 2009 | 10:51 AM
rriddle3's Avatar
This is normally a sign of mis-alignment. This web site shows some good illustrations to read tire wear.
Old Mar 19, 2009 | 10:56 AM
AJBert's Avatar
Have you rotated the tires at all since you put them on 30,000 miles ago? If not then that is your problem.
If you have been rotating every 5,000 miles or so like you should then it is an alignment problem.
Old Mar 19, 2009 | 11:18 AM
rriddle3's Avatar
I agree that tires should be rotated ~5-6k miles, but there is still an alignment issue that needs to be addressed. Better to be aligned and not rotated than rotated and not aligned.
Old Mar 19, 2009 | 11:31 AM
As already said, if you have not rotated your tires since you put them on, that is mostlikely the reason for the accelerated wear, but an alignment problem is also likely.
Another thing to note is that some tires do not last all that long. The factory tires on my Rainier only made it to 32k before they were toast. All four of them.
Ripley86
Sep 4, 2010 05:56 PM
fondo
Tires and Wheels
Oct 31, 2009 11:15 PM
Duram98jimmy4x4
Sep 18, 2009 10:53 AM
Duram98jimmy4x4
Sep 17, 2009 09:09 PM
kngflp
Suspension Tech
Nov 11, 2006 06:55 PM
