toe in, toe out
Old Oct 17, 2009 | 11:49 AM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
Default toe in, toe out
Hey all, The passenger side tire in the front was wearing on the outside pretty bad and come to find out that the idler was bad so i replaced that and that fixed the outside wear on the tire. I had a friend replace the outer tie rod end while i was at work on the drivers side because it was wore, and he said he counted the turns but it was rubbing really bad, so i turned it out a couple of turns and its a little better but still wearing on the out edge of the tire. I said he should have measured the tie rod length to get it accurate because the new tie rod end was a different length than the old 1, ( shorter rod with more threads) so now my question is if it is wearing on the outer edge of the tire a bit do I have to go in or out with the tie rod, I am thinking i have to go out a little bit. I am trying to get it pretty close so i dont have to spend 75 for an alignment
Thnaks
Old Oct 17, 2009 | 07:56 PM
jorge1's Avatar
jorge1 is on a distinguished road
when you drive straight is your steering wheel straight or off somewhat to the right or left.
Old Oct 17, 2009 | 08:36 PM
Nvidia78's Avatar
Steering wheel is to the right, and pulls to the right
Old Oct 17, 2009 | 08:55 PM
95BlackGA's Avatar
95BlackGA is an unknown quantity at this point
Well, there's your problem there. But really, sounds like it's had some sort of steering problem before, due to an off center steering wheel. It pulls to the right, when you're tryin' to driving straight, correct? Or is the wheel even off center, as in, you can't turn it to the left?
Old Oct 17, 2009 | 11:27 PM
jorge1's Avatar
Did you have good alignment before your work?. You need to lock the streeing wheel straight and it will take a few tries of adjusting it till you get it at the right spot it took me about 8 tries removing the tire and adjusting and test driving it Well worth it! then paying for an alignment. Your outer edge wear that would mean you have the tire pointing inward to much. Also did you check your ball joints.
Old Oct 18, 2009 | 08:03 AM
Nvidia78's Avatar
I did check the ball joints and they are good, only thing left I noticed is the pitman arm. I will jack it up today and adjust the tie rod out a little bit at a time and hopefully get it to where I want it, thats all I was trying to find out is if it needed to be cranked in or out
thanks
Old Oct 19, 2009 | 06:32 AM
Nvidia78's Avatar
Well I jacked the blazer up and gave it about a turn and a half out on the tie rod end and it is much better, the steering wheel is straight and it no longer pulls hard to the right. all I have left is to get the pitman arm changed and my new tires on and I will be set for this winter
Thanks
dimmuborgir6nik6
Apr 17, 2010 04:04 PM
fondo
Jul 22, 2009 05:35 PM
mick.p.
Jul 3, 2009 04:23 PM
ZLover4Life
Jun 23, 2009 08:09 PM
gmbwrenchn
Jan 21, 2009 01:09 PM
