torsion bar
Old Mar 28, 2012 | 10:25 PM
trevorh29's Avatar
trevorh29 is on a distinguished road
Default torsion bar
I just got a 95 blazer and i want to do a 2in lift i was told i could just raise the torsion bar so I'm wondering how many turns should i do before it is unsafe for the cvs and ball joints. and i i can do that could i just put a lift block in the rear
Old Mar 28, 2012 | 10:51 PM
pettyfog's Avatar
Old Apr 7, 2012 | 08:49 PM
minigunner1980's Avatar
minigunner1980 is on a distinguished road
well the rear would need a flip kit to use blocks cuz the springs run under the rear end and as far as the torsion bas i would just buy a 2 1/2 lift kit this will keep things were they need to be the torsion bars method will sag after time the ball joint angle and cv angle will be off and you will still have to get it to the aligment shop i lift kit will run you about 425-500 and then some time to install it depending on the tools you have and the help you have and mechancial know how
azzr2
Mar 25, 2012 04:19 PM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Mbastet99
Nov 7, 2006 07:52 PM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
