torsion bar
Old May 21, 2013 | 11:20 AM
davis_larry17's Avatar
davis_larry17 is on a distinguished road
Default torsion bar
ok i am new to working on suspension on trucks. I broke my lower control arm and just recently tried to put a new one on. the new control arm when i attached it to the torsion bar would not line up properly. the control arm was either pointing slightly up or straight down. i know neother of those are right so what do i do? is there a way to turn the torsion bar? and which way would i turn it? i am so confused sorry about this newb question. thanks so much
Old Jul 2, 2013 | 05:46 PM
dpannazzo's Avatar
dpannazzo is on a distinguished road
Hello,
Having the same problem right now.
Did you ever figure it out? I could use the help.
Thanks!
Old Jul 2, 2013 | 06:25 PM
okiedoak20's Avatar
With the front end on jack stands and the control arm at full droop and the torsion bar
Adjuster removed, the torsion bar should just slip into the control arm, then reinstall all adjusting parts and key, reassemble the knuckle assb. Tighten the adjuster bolt about
5 revolutions as a starting point, put tire on lower to the ground and fine tune height....
I have done this multiple times with no issues..
Hope it helps
Old Jul 3, 2013 | 08:39 AM
dpannazzo's Avatar
Thanks.
azzr2
Mar 25, 2012 04:19 PM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Mbastet99
Nov 7, 2006 07:52 PM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
