torsion bar question?
Old Jan 1, 2009 | 12:29 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Default torsion bar question?
Just wondering, i put new shocks in and when i hit a big bump in the road their is a loud squeeking noise. could my torsion bars be bad or set wrong? what is the stock distance that the bolts for the torsion should be in or out? s10 4x4 94 blazer is what I have.
Old Jan 1, 2009 | 12:31 PM
Default RE: torsion bar question?
There is no set measurement for the adjusting bolts as each torsion bar is different.
As far as the source of the squeak, you may want to try some spray lubricant around the bushings to see which one may be the culprit.
Old Jan 1, 2009 | 12:34 PM
rriddle3's Avatar
Good luck with the squeak. I have had suspension squeaks since I've owned the truck and have grease lubed and silcon sprayed everything that moves under the truck without success.
Old Jan 1, 2009 | 01:04 PM
correction, its less of a squeek and more of a poping sound when i hit a larger bump or dip in the road. i picked up some spray for the bushings so i will lube them up. i dont want the bolts all of the way in right, there has to be some happy medium.
azzr2
Mar 25, 2012 04:19 PM
mdehoogh
Suspension Tech
Dec 3, 2008 06:51 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
KenpoFish
Feb 5, 2008 08:38 AM
stevelknievel
Lifting Tech
Apr 23, 2007 12:57 PM
