Tranny fluid in my vaccum line???
Old Apr 29, 2009 | 06:06 PM
JAMES JONES's Avatar
JAMES JONES is on a distinguished road
Exclamation Tranny fluid in my vaccum line???
I have a 1990 s-10 blazer 4x4 with a 4.3. I am trying to figure out why my front dif is not locking in. I found that one of my vaccum lines was corroded and so as i'm replacing it, i find tranny fluid in it. It is the line that runs from the actuator to the tc. How come??? Anyone got any explanation for this???
Old Apr 29, 2009 | 07:44 PM
Been discussed many times before.
You have two problems that are combining to allow fluid into the vacuum system. The front seal on the transfer case is leaking allowing the transfer case to become over full and the vacuum switch on the transfer case which activates the front axle has failed and is allowing the fluid which is over full in the t-case to bleed into the vacuum system.
I hope, for your sanity, that it has not gotten into the HVAC system yet.
Old Apr 30, 2009 | 08:46 AM
How hard is that seal to replace do you know? And also, how would i know if fluid has gotten into my hvac system? I've read about that vaccum switch before. Is that the switch that the vaccum lines run into on top of the tc??? I really appreciate your help.
Old Apr 30, 2009 | 11:01 AM
The difficult part of replacing the seal is removing the transfer case. Well, I guess I should say it is more awkward than difficult. There really is no good way to support the t-case with a jack unless you make up something special.
Yes, the vacuum switch for the 4wd is located on the t-case. While you have the t-case down, replace the switch.
If you remove the HVAC control head and there is fluid in the lines there, then...
Old Apr 30, 2009 | 12:22 PM
ok, i'll get to that seal a.s.a.p. just to pick your brain again, which i'm sure you get this a lot, you seem like you know a lot, which lines should have vaccum and which one should not? i'm assuming that the line that goes towards the throttle body should always have vaccum and when the vaccum switch is opened there should be vaccum to the actuator. is this correct?
Old Apr 30, 2009 | 12:38 PM
There are three lines. One from the engine to the vacuum switch, one from the switch to the front axle, and then one that is just a vent line and should run up to somewhere on the firewall.
So yes, one should always have vacuum whenever the engine is running. The one to the actuator will have vacuum when the transfer case is in 4HI or 4LO.
Old Apr 30, 2009 | 01:17 PM
Awesome! Check out the pics i posted of the blazer! I love her! =)
Old Apr 30, 2009 | 01:29 PM
Looks to be in pretty good shape!
trishharris
Dec 2, 2011 04:23 PM
fattest1here
Jan 29, 2011 06:53 AM
Chevy Nova
18
Jun 4, 2010 06:46 PM
94blazer4.3ho
Sep 14, 2007 02:29 PM
guywm25
Dec 15, 2006 11:27 PM
