Transfer Case Output Seal
Old Jun 8, 2018 | 12:26 PM
Bravada01's Avatar
Bravada01 is on a distinguished road
Default Transfer Case Output Seal
So my 2001 Bravada AWD transfer case output seal, the one that is for the rear axle, is leaking on my car.
I tried a Duralast seal, it fit but leaked.
I tried a Masterpro seal from O'Rileys, it does not fit right. It pops out, and doesn't want to stay in. It will not seat all the way down.
Gonna try a Timken one after work.
The mating surface on the transfer case looks good. I know they make a repair sleeve for this area. I do not see anything wrong with the tail shaft on my transfer case. I guess just poor reproduction aftermarket seals.
Very odd..
Old Jun 8, 2018 | 10:02 PM
If you can find a National seal, use that. You can sometimes get them at O'Reilly, but they cost a little more than the store brands.
Old Jun 9, 2018 | 06:37 PM
Bravada01's Avatar
Changed it with a Timken one. Fit perfect.
I dont think it is leaking, but one of my trans cooler lines is leaking and coated stuff in trans fluid. Will keep an eye on it.
Old Jun 12, 2018 | 03:25 PM
Bravada01's Avatar
Tightened down trans cooler line. Seems to have stopped leaking.
Looks like my rear seal on transfer case is still leaking. The is fluid all around the seal, and in one spot I saw a drip. Repair sleeve? Ugh.
scphill34
Apr 7, 2013 05:05 PM
s-10fixer
Mar 20, 2011 12:05 AM
litterbug
Mar 7, 2011 09:14 PM
followme21
Aug 26, 2010 07:08 PM
GLBL WMR
Nov 14, 2009 05:54 PM
