Help with Trans Rear Seal
Old Aug 25, 2010 | 08:07 PM
followme21's Avatar
followme21 is on a distinguished road
Default Help with Trans Rear Seal
How in he world does a person change the rear output shaft seal in a 1997 Jimmy 4whl drive?? I have the 6-8 inch think piece that bolts on to the rear of the trans (held on by 5 bolts) off. But I see no way to get in there to get that seal out...I cant really even see a seal.. I'm not familar with these vehicles just helping a buddy out. Any help would be great,
The problem is the vehicle is dripping a little fluid from between the tranfer case and the trans...read that its probably this seal. The transfer case was overfull as well.
Thanks
Old Aug 25, 2010 | 08:16 PM
You don't. It doesn't exist. The seal you need to replace is in the front of the transfer case. Then seal up the mating surfaces with some RTV after cleaning everything up really well.
Old Aug 25, 2010 | 09:18 PM
followme21's Avatar
Thats kind of what I though, as I couldnt find a seal to purchase anywhere... but there seems to be some confussion by myself.. and othes I have read on other message boards. Why was the transfer case overfull. Some say factory does it. Others say it leaking in from the transmission..Like I said these vehicles are new to me so Im trying to fiqure things out..
Thanks again.
Old Aug 26, 2010 | 06:40 AM
followme21's Avatar
So if I understand everything correctly when the transfer case and the transmission are connected the transfercase front seal also acts as the transmission rear seal as well? That could explain why the transfer case was overfull? Is this what goes on in these vehicles?
Thanks
Old Aug 26, 2010 | 07:08 PM
Precisely.
killallblue
Aug 1, 2011 06:11 AM
xgiovannix12
Jun 9, 2011 11:56 AM
s-10fixer
Mar 20, 2011 12:05 AM
litterbug
Mar 7, 2011 09:14 PM
ccyne
Mar 20, 2009 07:00 AM
