Truck Squeaking Uncontrollably...
Old Mar 16, 2012 | 04:11 PM
AJC9725's Avatar
AJC9725 is on a distinguished road
Default Truck Squeaking Uncontrollably...
I have a 2000 Blazer 4 x 4 LT. It has 131,000 miles on it. Recently, whenever I drive on roads that aren't completely flat, it squeaks like crazy. It appears to be coming from the suspension, but I'm not sure exactly where. I thought it just might be that the truck is old and rusted on the underbody, and the winter caused some parts to shrink and start the squeaking, but the weather has been great the past few weeks, and the squeaking persists. I had the front upper control arms replaced, but that didn't help.
I have noticed that when I am turning and braking, the squeaking goes away, but whenever I am am going straight, and the road is uneven, I can feel the body swaying a bit, and it the sound is very obnoxious. Anyone have any suggestions for a quick fix or a direction to look in? Thanks.
Old Mar 16, 2012 | 06:13 PM
warthogdriver's Avatar
my first thought is check the grease in all your suspension parts.
i think on a standard 4x there are 12 points to grease...depending on you parts if they are sealed after market or not.
i would start there...you may find a torn boot or best case just a dry socket
Old Mar 18, 2012 | 06:01 PM
AJC9725's Avatar
Not particularly technically advanced when it comes to car maintenance. Can you tell me or direct me somewhere to find out where these 12 grease points are?
Old Mar 20, 2012 | 01:26 PM
RedSquirrel's Avatar
RedSquirrel is on a distinguished road
ball joints, tie rod ends, idler arm, pitman arm, and u-joints if they have been replaced, i think thats all of them.
Old Mar 20, 2012 | 10:27 PM
NHRABill's Avatar
NHRABill is on a distinguished road
It is that time of year my Wife's 2004 SRX was squeaking last week so I grabbed some WD-40 hit every rubber bushing I could find and voila all gone. The Cadillac doesn't have any grease fittings they are sealed. depending on where you live moisture levels and temperature the rubber will squeak. This is also why I buy WD-40 by the gallon always have an old spray bottle or 3 around for a quick squeak fix.
As suggested by others never hurts to check grease fittings for failure. And if you are not a hands on person the job of a quick oil lube place is to lube and grease the chassis. They may charge 20 bucks to lube the car up so it might be worth it to you and have it looked at they might find something wrong that you may have not looked for or seen.
Old Mar 21, 2012 | 01:14 AM
50lb_cat's Avatar
You can also pry the leaf springs apart and spray some lithium grease between the leafs. If the noise is coming from the rear. +1 on previous posts though.
Old Mar 21, 2012 | 06:41 PM
AJC9725's Avatar
With some help, I replaced the sway bar bushings at the wheel connection on both wheels. This did not help much however, even though the bolts through the old bushings looked as if they would shear at any moment. I will take your guys advice and WD-40 all of the chassis to see if that helps.
I was also told that that there are two other split-bushings on the sway bar more towards the front center of the truck under the radiator that look easy to replace. Thanks for your guys help and advice.
Old Mar 21, 2012 | 07:06 PM
tjmicsak's Avatar
tjmicsak is on a distinguished road
check each side by lifting and pushing down the front fenders/wheel wells.
What you're describing sounds like what my ball joint was doing. Broken grease nipple and dry ball socket.
bobby099
Dec 22, 2018 09:41 PM
bigdaddykane93
Jan 27, 2016 11:35 PM
er0ck273
Jul 31, 2015 04:10 PM
blazerman
May 29, 2006 10:39 PM
tpendergraft85
Feb 17, 2006 07:10 AM
