Very Rusty drive shaft Fix
Old Feb 7, 2015 | 01:38 PM
Sunfish's Avatar
Sunfish is on a distinguished road
Lightbulb Very Rusty drive shaft Fix
My shaft had cancer and I fixed it in about 45 minutes. I jacked the back wheels off the ground and chocked the front to where it would sit still. Started it up in neutral and took a 80 grit belt that I cut in two and went at it. Finished up with Scotch brite pads. When I got it cleaned up I took some Krylon rust silver and painted it while still spinning and it looks much better and has no vibrations or anything. Sunfish
Old Feb 7, 2015 | 04:10 PM
mr.vls's Avatar
I did almost the same thing. See the link below.
https://blazerforum.com/forum/paint-...leaning-45097/
Old Feb 7, 2015 | 07:44 PM
TZFBird's Avatar
TZFBird is on a distinguished road
You've got a pair if you are going to hold onto something wrapped around a rotating object with no way to stop it. In the name of safety I would not recommend putting anything around the shaft to sand or clean it. If anything using a wire wheel would be safer. I'm glad you left it in neutral so you had a chance had the sanding belt caught and pulled you in.
https://m.youtube.com/watch?v=N9grSq-TWMQ#
Old Feb 7, 2015 | 09:02 PM
mr.vls's Avatar
When I did mine I flat sanded only. Nothing was wrapped around the drive shaft.
Old Feb 7, 2015 | 09:11 PM
Sunfish's Avatar
I could nearly stop the shaft with the belt.
Old Feb 7, 2015 | 09:21 PM
TZFBird's Avatar
I understand you can pretty much stop it with the paper or even by hand, but things can happen and someone else might not be as lucky in the future.
Old Feb 8, 2015 | 09:03 AM
rexazz2's Avatar
I try to keep my shaft clean and lubed often
Old Feb 8, 2015 | 05:44 PM
Sunfish's Avatar
Send us your partners E-mail and we will confirm the details
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
DaveC
Jan 4, 2010 08:13 AM
dart
Feb 8, 2008 09:49 AM
Kellen
Sep 22, 2006 04:41 PM
