Vibration after 60-65mph
Old Nov 20, 2017 | 04:36 PM
iceblue068's Avatar
iceblue068 is on a distinguished road
Default Vibration after 60-65mph
Have anyone ever had this problem? What did you do to fix it? Changed u-joints,tires,no solution.
Old Nov 20, 2017 | 10:54 PM
I'm assuming you had the tires balanced. What year and what motor? Can the driveshaft be out of balance?
Old Nov 21, 2017 | 06:10 AM
chevyriders's Avatar
If it's the blazer in your profile picture i would suspect tires out of balance- low profile tires on large diameter wheels are a pain to get properly balanced...my dad has had issues even with the stock 20s that came on his Dodge ram. He had the new tires(nice quality ones not cheap ones) balanced 3 times before the highway vibration subsided..and it's still not perfect.
I would also check for a bent rim.
As Christine said, it could also be a driveshaft out of balance- but unless you're taking it off road(which I'm assuming you aren't if that's your blazer) and bent/dented it- its less likely
On the note of driveshafts, if it is 4x4 did you do both front driveshaft u joints, and both rear u joints?
Old Nov 21, 2017 | 11:25 AM
iceblue068's Avatar
Yes,that's the Blazer in the pic,it is a 98' w/4.3 2wd. I haven't had the driveshaft bal. but I had the same problem with 15" wheels but I will start with balancing the wheels. New engine btw
Old Dec 26, 2017 | 09:14 AM
Foxclub83's Avatar
Foxclub83 is on a distinguished road
Default Belt separated.
I had a similar issue once and it was simply a separated belt in one of the tires. New tire fixed it.
gothicsera
Dec 2, 2015 01:15 PM
michael.tucholsky
Aug 22, 2010 10:57 PM
jshultz78
Dec 24, 2009 03:13 PM
joseph617
19
Aug 25, 2009 12:03 AM
Big Windy
May 13, 2008 08:45 AM
