weird steering angle
Old Apr 25, 2013 | 04:30 PM
Steve-o's Avatar
Steve-o will become famous soon enough
Default weird steering angle
my steering is like i have to have it like im turning right slightly to go stright. yet i have new steering box, idler arm, pitman arm. ball joints are good, rag joint is good. i have significant wear on my front passanger tire. yet my TOE is perfect. ideas?
pic of my steering angle while driving stright.
Old Apr 25, 2013 | 05:02 PM
okiedoak20's Avatar
sounds like a front alignment is in order, from the alignment guys i deal with, camber also plays a role in the pull of the car.. so sometimes if a vehicle is pulling lets say to the right, it may not be the toe angles but the camber angle
Old Apr 25, 2013 | 05:48 PM
Steve-o's Avatar
make sense. any other ideas to try out before shelling out money.
Old Apr 25, 2013 | 07:32 PM
swanman35's Avatar
swanman35 is on a distinguished road
When I changed my spark plugs I disabled the steering shaft. When I got It all together it was a little off(even though I was told it's impossible to do). So I took it apart again and redid it and it was fine.
Old Apr 25, 2013 | 11:01 PM
Twip's Avatar
rotate the tires from the front to the back. dont cross rotate them. just front to back and see what it does. if the wheel straightens out, you should start checking hubs and ball joints. something could be on the way out, or broken all together.
edit: mine was doing the same thing, i did a tire rotation and the wheel straighten out. when i bought mine the PO said that he had the upper ball joint replaced that morning. (right before i bought it) when i took it on a test drive before i bought it, i didnt notice the wheel being off. but after the tire rotation and new tires all together, its fixed.
Old Apr 25, 2013 | 11:25 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Is there any play in the wheel from there to center? If so mine does the same exact thing when my Idler goes out, which my wheel is now like yours after mudding.. But what brand parts did you use for all that? If you use something cheep and not Moog the parts may only last a couple months.
Old Apr 26, 2013 | 09:11 AM
Steve-o's Avatar
it was over 2 years ago since the parts were bought, but my dad works part time at advance auto so discounts, wootwoot! and just your typical play in the blazers, back when i got it, the play was horrid. then bought a new steering box. thats when i first noticed the steering angle off, but it took the guy forever to actuly get it in (he said a week it was a month) so i didnt want to take it back to him knowing that.
Old Apr 26, 2013 | 04:39 PM
Wait wait.... a month to get a steering box in????? Lol that should only take 3 hours and that's going slow. But if the angle has been off since the box was put in then this "mechanic" didn't align the shafts.
Old Apr 26, 2013 | 05:01 PM
Steve-o's Avatar
thats what i thought too.
Old Apr 26, 2013 | 07:33 PM
Steve-o's Avatar
does it help that my front is a half and inch higher then my rear lol. looks like i need to go crank down the t-bar. XD
kevlar974
Jun 6, 2011 07:49 PM
wlorton
Lifting Tech
Jan 26, 2010 12:28 AM
burningsun
Lifting Tech
Aug 2, 2009 01:14 AM
bobditts
Sep 3, 2008 09:58 PM
AK8BLANK
Suspension Tech
Mar 3, 2007 07:55 PM
