susp. lift vs drive shaft angle?
Old Sep 2, 2008 | 09:49 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default susp. lift vs drive shaft angle?
Anyone know what the largest suspension lift you can put on a stock 1st gen s10 blazer without having to modify the driveshaft?
Old Sep 2, 2008 | 09:52 PM
Default RE: susp. lift vs drive shaft angle?
Typically the larger lifts change the pinion angle on the rear axle. The 6" suspension lifts available (that drop the front axle) should do this and I do not believe that any of them require a longer drive shaft.
Old Sep 3, 2008 | 06:41 AM
bobditts's Avatar
isnt changing that angle a bad thing though?
Old Sep 3, 2008 | 06:56 AM
If you go the wrong direction, yes. But the kits are engineered to correctly change the pinion angle for better alignment of the driveshaft to the rear axle. The driveshaft angle at the other end gets worse, but I do not believe it gets bad enough to be of much concern. There are many people running these suspension lifts.
Old Sep 3, 2008 | 09:46 AM
bobditts's Avatar
that is excellent news to hear. any links to the kit you are talking about?
Old Sep 3, 2008 | 09:51 AM
Take a look in the Lifting Tech section for a list of lifts available.
Old Sep 3, 2008 | 08:00 PM
bobditts's Avatar
DANG I didnt even see that section! What is the difference between this suspension section and that one?
Old Sep 3, 2008 | 08:37 PM
This is for stock suspension maintenance. The other is for modification.
Old Sep 3, 2008 | 09:58 PM
bobditts's Avatar
oh! You should move this one then since it doesnt belong if you want to.
dustinhxc
Lifting Tech
13
Feb 1, 2013 04:27 PM
blake6dirt
Lifting Tech
Apr 26, 2012 06:16 AM
warthogdriver
Feb 15, 2011 10:50 PM
C.Blazer
Lifting Tech
32
Dec 2, 2009 08:05 PM
burningsun
Lifting Tech
Aug 2, 2009 01:14 AM
