What gives a ZR2 the lift?
Old Apr 10, 2008 | 11:11 PM
rickyp3278's Avatar
rickyp3278 is an unknown quantity at this point
Default What gives a ZR2 the lift?
I'm sure this is a dumb question, but what makes the ZR2 sit so much higher than the LS Blazers? Is it a factory suspension lift? Body lift? Just curious. Help me if you can.
Rick
Old Apr 11, 2008 | 09:55 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: What gives a ZR2 the lift?
2" larger tires (netting 1" of height)and a 2" factory suspension lift.
Old Apr 11, 2008 | 10:00 AM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
frames are differnet this is the most of the lift..
Old Apr 11, 2008 | 10:14 AM
Jigg's Avatar
Right... the suspension lift is acheived by modified mounting points on teh frame for the suspension.
Old Apr 11, 2008 | 11:28 PM
rickyp3278's Avatar
makes sense. Thanks fellas. Just installed add a leafs on my blazer...rear was sagging a bit. Now it sits just above level...very slightly raked look. Lovin it.
Old Apr 12, 2008 | 12:00 AM
WolfPack's Avatar
Isn't that kinda like saying what gives a F150 it's lift?
The ZR2 is a completely different vehicle than an S10 blazer to me (different frame, different axles, the tires/wheel wells difference..). It's not really a 2' suspension lift if the mounting points are different from where they lie on a S10 blazer...it's a different suspension setup right?
Edit:ok maybe not completely different, but it's obviously different enough you have to buy parts specific for a ZR2 as opposed to S10 blazer...different enough
NCSurvival
Nov 6, 2014 05:36 AM
naveedmerchant
Dec 2, 2013 08:41 AM
Johnny Glenn
Mar 12, 2010 10:18 AM
SmoyMoose
Lifting Tech
Mar 11, 2010 09:57 PM
warthogdriver
Lifting Tech
14
Feb 28, 2010 06:00 AM
