what u-joint to buy
Old Jan 27, 2009 | 05:32 PM
offskooring's Avatar
offskooring is an unknown quantity at this point
Default what u-joint to buy
i have 1977 k5 blazer...i have no clue about the market for u-joints...i had to replace one in the rear and i just got one from napa for $25...i was wondering if there are stronger, better made u-joints(prob more expensive) that i should be purchasing.
adam
Old Jan 28, 2009 | 06:41 AM
Default RE: what u-joint to buy
Napa u-joints are not too bad. Are you doing something with the truck that makes you think that you need to have better u-joints? As long as you keep them greased, you should be good for quite awhile.
Old Jan 28, 2009 | 09:54 AM
79cheyenne's Avatar
79cheyenne is an unknown quantity at this point
Napa u-joints are decent. Do you have a lift on it? If so, no u-joint will hold up unless you drop the t-case and rotate the axle, or get a cv shaft. If no lift just make sure you keep them greased.
4.3vortec
Apr 1, 2014 09:17 PM
josemateos
Feb 18, 2014 10:00 AM
big_charms@hotmail.com
Mar 25, 2013 08:12 PM
Guntheone
Dec 4, 2010 05:59 PM
mikekolb
Jul 26, 2009 11:59 PM
